Thread Number: 63
"FS98 and 2000"
Posted by Elmer Chen [Passenger] on 07-16-01 at 01:34z
I installed both of the above in my computer. Now I want to uninstall FS98. I heard the rumour that the uninstallation of FS98 now will affect FS2000. Is it true?
"RE: FS98 and 2000"
Posted by Hodgo on 07-16-01 at 02:54z
http://www.flightadventures.com/Forum/htdocs/dcforum/Images/appxuu.gif
____________________
That rumour is untrue. FS98 and FS2000 are stand-alone games and are completely separate of each other in their installs.
Just be sure to uninstall FS98 using the uninstall option from Control Panel > Add/Remove Programs and you should be fine.
-Stephen.
"RE: FS98 and 2000"
Posted by Ben Chiu on 07-16-01 at 10:10z
Ditto, of course, unless you've installed FS2K into your FS98 folder. If you've done that, all bets are off. :)
"RE: FS98 and 2000"
Posted by craiggresham on 07-24-01 at 17:02z
http://www.flightadventures.com/Forum/htdocs/dcforum/Images/8akkw.gif
i have had both FS2000 and FS98 installed on my computer and uninstalled FS98 and had no problems.
Craig G
"RE: FS98 and 2000"
Posted by Chen [Passenger] on 07-24-01 at 17:28z
My origional ambition is to install boths so that I can play boths.May be I should say I am a little bit greedy. I find out I never enjoy FS98 anymore after seeing the graphic of FS2000. I like to see whelther there are any others having the same feeling like me.Now FS2002 is coming and I hope I will not go into the same temptation again.
"RE: FS98 and 2000"
Posted by craiggresham on 07-24-01 at 17:41z
I am with yah. I currently have fs98 and 2000 installed. The main reason for having fs98 installed is because other people that do not have fs2000 we can not use the multi-player. The scenery and aircraft are much nicer in fs2000 so it is my sim of choice.
Craig G
