While reviewing fs2002 scenery.cfg it was noted that several mismatches of area numbers and layer numbers existed. Supposedly the following for any scenery should have the same numbers as in:
Layer=3After manually correcting the file, a scenery was removed via the fs2002 scenery menu. This resulted in one mismatched scenery number. Is this a known bug in fs2002?
Jim Jones
Greetings Jim:> After manually correcting the file, a scenery was removed via the fs2002
From Al Wheeler:
=============================snip===================
It probably is a bug and seems to be universal, but it doesn't appear to bite. I have seen my SCENERY.CFG Area and Layer numbers mismatched and the Areas out of numerical sequence but it doesn't cause any problems that I can see. I used to straighten them out with a text editor for the sake of neatness but think it was a waste of time. I've found that eventually FS reorganizes them if you leave them alone. The significant number is the Layer in any case.
==============================snip==================
Sorry it took a while to get you an answer. Hope it helps!
