Thread Number: 483
""End it all""
Posted by Bob on 05-18-02 at 10:16z
Hi folksFirst of all let me say that the "Blackpool" thread has not given me the inclination to jump off the tower, I was in Blackpool to see a customer this week and actually went into the town to take a look. Have to say the tower does look more impressive from a distance!! Could not resist the "Fish and Chips", they were delicious.
Now to the real point of my post. I am running XP and "end it all" does not work with this prog.
Can anyone tell me which tasks must be left running in XP and which can be turned off. Maybe I do not need to bother when running XP but any comments would be appreciated.
Kind regards
Bob Buckley
Coventry
UK
- RE: "End it all",James, 10:38z, 05-18-02
- RE: "End it all",Bob, 15:11z, 05-18-02
- RE: "End it all",PaulCroft, 11:54z, 05-19-02
- RE: "End it all",James, 17:44z, 05-19-02
- RE: "End it all",Bob, 21:29z, 05-20-02
"RE: "End it all""
Posted by James on 05-18-02 at 10:38z
Hi Bob,Don't know why my OLR never picked this one up
Anyway, I have XP running on quite a few machines and installed End It All and it works OK my end. The only prog I see still running after is both Explorer and End It All which are both protected.
If you happen to get an out of memory error just click on the close button or OK button, highlight the prog that has not closed and run end it all again.
"RE: "End it all""
Posted by Bob on 05-18-02 at 15:11z
Hi JamesThanks for the quick response.
I will download end it all again and give it another try.
Bob
"RE: "End it all""
Posted by PaulCroft on 05-19-02 at 11:54z
HI Bob>> I am running XP and "end it all" does not work with this prog. <<
It does on my XP system - are you using version 2.0.0.0?
++++ Registered to: Paul F. Croft ++++
"RE: "End it all""
Posted by James on 05-19-02 at 17:44z
Hi Paul,>> are you using version 2.0.0.0? <<
Nope not here
I'm still on v1
++++ Registered to: James Anderson ++++
"RE: "End it all""
Posted by Bob on 05-20-02 at 21:29z
Hi PaulDo not know why I had a problem previously but I tried again and it worked. I have downloaded "end it all 2" and I am using it now without any problems.
Thanks for the help.
Kind regards
Bob Buckley
