Thread Number: 472
"Sunday Flight 5/5/02"
Posted by James on 05-02-02 at 19:02z
Hi Guy's,
Just to let you all know that the first Sunday Sightseeing Flight will be taking off from Leeds Bradford Airport (EGNM) at 20:00BST. There will be flight rooms available to FS98/FS2000/FS2002 users Please ensure (for ease of use etc) that if you haven't installed Roger Wilco it's advisable to :-)
Please also take a look at Ground School - Radio Procedures.
Hope to see a few of yous in the Flight Terminal.
++++ Registered to: James Anderson ++++
"RE: Sunday Flight 5/5/02"
Posted by jerryrosie on 05-03-02 at 18:21z
Hi James -
What type of aircraft will we be flying on Sunday so I can get everything ready to meet you on rwy 32 and can keep up as you lead us around town...??
++++ Registered to: Gerald J. Rosie ++++
Posted by James on 05-03-02 at 19:48z
I will be flying in either the Cessna RG or the Bell 206 :-) This will be a leisurely trip of about an hour or two :-)
See you on the ramp....
Posted by jerryrosie on 05-05-02 at 08:55z
rgr - Thanks.....
Posted by AlanParkinson on 05-06-02 at 01:24z
Hi Jerry, Ben and co.
If my multiplayer fiasco today spoiled your enjoyment I do apologise, thanks for the patience and perseverance. I'd like to crack the problem, but with the cost of a two hour telephone connection in the UK being so high, I really can't justify wasting much more time without success. One more try perhaps.
Ben, you could be right about the shared modem connection's IP being hijacked by the server sharing it - do you have a note of the IP you were seeing? But in the recent trial run for multiplayer, I DID manage to connect and fly successfully when Jerry was hosting (I think I had trouble connecting when you were the host). At that time I didn't have RW running - maybe the problem is just too much workload for my poor little 233MHz CPU.
During my 45 minute absence in the middle of the flight, I installed a local modem, and logged on again shortly before you all landed. My first observation with the new modem, once I'd got the settings right, was that the computer was responding very roughly, sluggishly, even before starting FS. I found Jerry still had a flight running so I tried to join that. Twice I managed to connect and start FS, but on both occasions the modem lost the connection more or less immediately after I started flying.
++++ UNREGISTERED ++++
Posted by AlanParkinson on 05-06-02 at 13:36z
Ben, a follow-up to my previous message.
When I installed the local modem, I didn't get the settings quite right - it looks like I was talking to the ISP, but their system was dropping the connection after a short time. Made a few changes now, and it seems to stay connected. My machine is also running much more smoothly again after the changes - it may be worth another try after all.
Posted by vgbaron on 05-06-02 at 16:25z
Alan -
Always happy to help, no need to apologize. We're all trying to enjoy our hobby and we've all had to go thru the setup frustrations<g>. Hang in there - it will get sorted out eventually and from your other posts - you seem to be on the right track.
Posted by James on 05-06-02 at 20:08z
Hi Alan,
No need for an apology my friend. We were all having problems :-) one way or another :-)
It was suggested/mentioned that it maybe a Network problem but Mike and I started 2 more flights from Networked pc's :-)
so it's baffling to say the least at present :-)
Week end and public holiday prices for the UK (Local Calls) are fairly good these day's are they not. I moved to BT ADSL some time ago so I no longer look at how long I'm connected :-)
Posted by Ben Chiu on 05-06-02 at 21:38z
Greetings Alan:
> were seeing?
Sorry, I didn't write it down.
I'm on a new satellite connection and haven't played with it enough to know whether it's stable or not. This is why I had Jerry host the flight since he's on a straight dialup. A setup like his removes many potential problem areas so my thoughts were that it would help isolate the problem. Since you're able to connect to Jerry, and I read in another message that you got your modem issues sorted, I think that you'll be fine connecting to the others.
Welcome aboard!
Posted by AlanParkinson on 05-07-02 at 19:02z
Not a problem, but as the NT machine has a permanent IP, that would have confirmed one way or the other. (But surely, if NT is sharing the modem simply as a hardware device to a W98 machine, NT has no right to change the data on the way through?)
Yes, it should be worth another try, I may even get a headset microphone instead of the very expensive studio mic that I borrowed for the event.
