Hi sipapu:> Does anyone know where I
> might obtain some decent programming literature for this stick?
For all things stick-worthy, I usually try www.stickworks.com first. What I found there was this link http://saitekhelp.simhq.com/
Hope this gets you started.
**** VPC OffLine Reader Version 3.0.4.1 **** RC 1 ****
Hi sipapuIf your just using the stick for FS2002 all you need to do is install the drivers, theres not much point for the programming software, as FS2002 detects all the buttons/rotarys on my X36, and you can assign them within FS2002
Cheers
Sam Harvey
sam@crew.flightadventures.com
As an existing user of the Saitek X36 as well I can confirm the 2 bits of advice already given.The link Ben gave to simhq is an absolute must for X36/45 users, proper help from users, not the pathetic thing from Saitek
As Sam said if you only use it in FS2k/2k2 you probably won't need the programming bit of the software as you can assign most of the buttons through FS.
However if you decide later you want/need to program the buttons then check out the excellent tutorials at the simhq site. Programming can be a daunting at first until you get your head round some of the concepts.
A great combo and a good price, even better when you substitute CH Pedals
Vulcan
8nm NE of EGCC
