Thread Number: 420
"FS98 crash"
Posted by Guido_Ostkamp on 03-22-02 at 14:05z
Hi all,
on my notebook I am still using FS98 on Win98SE. When I try
to add new scenery and use the "search drive" button in the
scenery management window, FS98 crashes with a fault in
Kernel32.dll.
However, I can still add scenery by using add files options
and typing in the complete path manually (sorry, if the menu
entries look differently for you, because I can only guess
the english terms as I am on a German FS98 here). Disabling
or re-enabling scenery which is already installed works well
too, so the problem is not related to recalculating the
scenery index database.
I don't want to reinstall because a lot of addons has
already been added.
Any ideas what causes this problem?
Guido
**** OLR.PL Build 1.74 ****
"RE:FS98 crash"
Posted by PeteDowson on 03-23-02 at 00:57z
Hi Guido,
> Kernel32.dll.
I seem to recall that option never worked properly anyway, though I can't remember whether it crashed or not. My memory isn't what it used to be back then! <G>
"RE:FS98 crash"
Posted by Guido_Ostkamp on 03-23-02 at 21:08z
Hi Pete,
I never had any problems with that on my main system, just on this
notebook. I thought it could be a problem of having too long pathnames
or too much directories or files. However, the interface never was
comfortable at this point.
Guido
"RE:FS98 crash"
Posted by Ben Chiu on 03-23-02 at 02:48z
Greetings Guido:
> Kernel32.dll.
Can you post the complete error message?
Kernal32 errors have been known to be caused by many things from bad video drivers, the wrong version of DX, and incompatable soundcards (the DFI SC-211/ESS 1868 chipset comes to mind).
"RE:FS98 crash"
Posted by Guido_Ostkamp on 03-23-02 at 21:09z
Greetings Ben,
> > Kernel32.dll.
yes. I did the test twice, first time without, second time with Dr.
Watson activated. Here's the output (Dr. Watson stuff shortened):
Without Dr. Watson:
FLTSIM98 verursachte einen Stapelfehler in Modul KERNEL32.DLL bei 0167:bff7429f.
Register:
EAX=81622ec8 CS=0167 EIP=bff7429f EFLGS=00200283
EBX=00562060 SS=016f ESP=00562014 EBP=00562044
ECX=c156b290 DS=016f ESI=0056208f FS=2b57
EDX=bffc9490 ES=016f EDI=0000002c GS=0000
Bytes bei CS:EIP:
eb 95 8b 54 24 04 50 e8 04 00 00 00 58 c2 04 00
Stapelwerte:
bff741f7 bffc9490 bff7cdf9 bffc9490 005621e1 0056208f 005621b8 0056203c 00000000 00562091 005621e1 bffc9002 00562064 bff7ceed 0056208f 00000104
With Dr. Watson:
*----> Details <----*
Command line: "C:\fs98\FLTSIM98.EXE"
Trap 0c 0000 - Stack fault
eax=8163b8a4 ebx=00562060 ecx=c159fa50 edx=bffc9490 esi=0056208f edi=0000002c
eip=bff7429a esp=00562014 ebp=00562044 -- -- -- nv up EI NG nz na PE CF
cs=0167 ss=016f ds=016f es=016f fs=34bf gs=0000
KERNEL32.DLL:_FREQASM+0x329a:
>0167:bff7429a e834250000 call bff767d3 = KERNEL32.DLL:_FREQASM+0x57d3
sel type base lim/bot
cs 0167 r-x- 00000000 ffffffff
ss 016f rw-e 00000000 0000ffff
ds 016f rw-e 00000000 0000ffff
es 016f rw-e 00000000 0000ffff
fs 34bf rw-- 8163b8a0 00000037
gs 0000 ----
stack base: 00560000
TIB limits: 00560000 - 00660000
-- exception record --
Exception Code: c00000fd (stack overflow)
Exception Address: bff7429f (KERNEL32.DLL:_FREQASM+0x329f)
KERNEL32.DLL:_FREQASM+0x329f:
>0167:bff7429f eb95 jmp bff74236 = KERNEL32.DLL:_FREQASM+0x3236
0167:bff7427f a1e09cfcbf mov eax,dword ptr
0167:bff74284 8b00 mov eax,dword ptr
0167:bff74286 0fba704407 btr dword ptr ,07
0167:bff7428b 73a9 jnc bff74236 = KERNEL32.DLL:_FREQASM+0x3236
0167:bff7428d 8d400c lea eax,
0167:bff74290 50 push eax
0167:bff74291 6a00 push +00
0167:bff74293 6a00 push +00
0167:bff74295 68fd0000c0 push c00000fd
*0167:bff7429f eb95 jmp bff74236 = KERNEL32.DLL:_FREQASM+0x3236
0167:bff742a1 8b542404 mov edx,dword ptr
0167:bff742a5 50 push eax
0167:bff742a6 e804000000 call bff742af = KERNEL32.DLL:_FREQASM+0x32af
0167:bff742ab 58 pop eax
0167:bff742ac c20400 retd 0004
0167:bff742af 833dec9cfcbf01 cmp dword ptr ,+01
0167:bff742b6 0f8c7affffff jl bff74236 = KERNEL32.DLL:_FREQASM+0x3236
0167:bff742bc e951ffffff jmp bff74212 = KERNEL32.DLL:_FREQASM+0x3212
0167:bff742c1 8b0de89cfcbf mov ecx,dword ptr
0167:bff742c7 8b09 mov ecx,dword ptr
-- stack summary --
016f:00562044 0167:bff7429a KERNEL32.DLL:_FREQASM+0x329a
(0056208f,00000104,0056208f,00562060,
206e207a,005620b6,00562194,bff7636f)
016f:00562064 0167:bff7ceed KERNEL32.DLL:.text+0x3eed
(005621b8,00000000,0056208f,005621e1,
206e207a,005621b8,00000000,005621b8)
016f:00562194 0167:bff7636f KERNEL32.DLL:_FREQASM+0x536f
(005621b8,03837114,0383f3d0,fffffffe,
00000001,206e2078,03837110,505c3a43)
-- stack trace --
0167:bff7427a e855d1ffff call bff713d4 = KERNEL32.DLL!1
*0167:bff7429a e834250000 call bff767d3 = KERNEL32.DLL:_FREQASM+0x57d3
"RE:FS98 crash"
Posted by Ben Chiu on 03-23-02 at 21:53z
Greetings Guido:
That's what I was afraid of--a generic FS98 and Kernal32 error.
If you have the FS patches installed, not running the ESS chip-based soundcard, have updated drivers, and have DX6a or later installed, the only other things I can suggest trying is turning down your hardware acceleration for graphics and your soundcard. If none of those cure it, try disabling all of the addon scenery that you have and see if you still have the problem.
If you do, you'll have to remove and reinstall FS98 to start fresh to try and track down what's causing the error.
Sorry couldn't be of more help.
