Thread Number: 412
"nVidia Emblem in 3D screens?"
Posted by PeteDowson on 03-19-02 at 10:58z
Hi folks,
All of a sudden, since yesterday, I'm getting an embossed-looking nVidia emblem in the bottom right corner of FS2002 and FS2000 3D windows. I don't know what I've done to deserve it, and I can't find the option, if there is one, to get rid of it.
I seem to remember this happening to someone back in CompuServe's FSForum, but I've gone and deleted my complete OzWIN installation now and can't check the archived messages.
Anyone here know how to remove this annoying advertisement, please?
**** OLR.PL Build 1.72 ****
"RE: nVidia Emblem in 3D screens?"
Posted by Tarmack on 03-19-02 at 11:11z
Pete,
I do remember reading that there IS an option to turn on this logo in 3D mode....and so there must also be an option to turn it off.
I believe that the option is only for the Ti cards....I know it is in my GeForce4 Ti 4600...but can't remember seeing it in the GeForce 440's.
Mel
Posted by PeteDowson on 03-19-02 at 14:28z
Hi Mel,
Yes, I seem to remember that, but it isn't in the display properties. I'll probably need to get rid of it by editing the Registry, but I had a look and there's nothing obvious.
Oh, I've got nothing that up-to-date. This is on a GeForce 2 Ultra, using drivers 10.50 (normally). I've tried several different driver versions over the last few hours but the emblem is still there and I've not seen any option yet.
Posted by Emile on 03-19-02 at 15:46z
Hi guys,
I think :
Start, settings, control panel; display (double click); settings ; advanced ; there you see Nvidia tab; click on and there is a "check" for the Icon Nvidia ; uncheck
for Win 98 SE
Posted by Emile on 03-19-02 at 16:28z
>Hi guys,
>I think :
>for Win 98 SE
>Regards
>Emile
>EBBR
Correction : settings; advanced; other settings; Nvidia; Settings Direct 3D; there is the check/uncheck for the Icon
Posted by PeteDowson on 03-19-02 at 18:22z
Hi Emile,
> for Win 98 SE
I'm using Win98SE, but there's no checkbox for an Icon
Could you tell me the version number of your nVidia drivers, please? If I install those then I should be able to switch the emblem off even if I then go back to 10.50 -- or at least I can detect which Registry item is being changed. I think it must be merely a bit in a set of property flags. There's no key suggesting this property by itself.
Thanks,
Posted by Emile on 03-19-02 at 19:20z
Hello, I am running 23.11 driver
Posted by PeteDowson on 03-20-02 at 01:20z
Hi Emile,
Great! Cracked it! I installed that, found the option, disabled it, checked it in FS (okay), simultaneously verifying that this driver caused my FS2000 and FS2002 to hang solid*, went back to my favourite 10.50 drivers, and the emblem is gone!
* I don't know why but all drivers 12.xx and later hang the PC with FS2000 or FS2002 on my PC. Sometimes this is almost immediately, sometimes after a few hours. Version 10.50 I found never seem to hang, so I'm sticking to them, at least till I upgrade my video card! <G>
Posted by Guido_Ostkamp on 03-19-02 at 19:12z
Hi Pete,
>archived messages.
I checked my CIS message base and found this article:
>>I have had this on my GeForce 3.There is an option in the settings to turn it off.
To get ther I did the following.
Start
Control Panel
Display Properties
Settings
Advanced
GeForce3
Additional Properties
Direct 3D
Uncheck "Display Logo when running Direct 3D applications."
Hope this helps. I am running the 21.83 drivers but I would think the settings would be the same for the 14.10 drivers.<<
Guido
Hi Guido,
No, nothing like that in any of my older drivers. But I fixed it thanks to Emile -- see my reply to him. I had to install later drivers, turn it off, then go back to my working drivers as later ones hang FS on my PC.
Thanks,
Posted by jonahbird on 03-20-02 at 00:24z
Hi Pete
It was I :-)
Bob Buckley of Coventry produced the answer and, if I can, I will copy his reply herein:
>>Hi Frank
To get there I did the following.
Start
Control Panel
Display Properties
Settings
Advanced
GeForce3
Direct 3D
Kind regards
Bob Buckley
Coventry
UK<<
Cor!! I think I,ve done it. I do remember that earlier versions did not have this default nuisance and to get rid of it you had to restore the version which put it in.
Best regards
Frank
"Driver performances Nvidia"
Posted by Emile on 03-20-02 at 07:15z
For those who are interrested, following site gives some performance data for Nvidia
http://guru3d.com/detonator-dbase/
Hope it helps
"RE:nVidia Emblem in 3D screens?"
Posted by jerryrosie on 03-20-02 at 13:16z
I still have some of those messages on my hard drive but, unfortunately, the message giving the answer to the unwanted logo had already scrolled off. Hope someone else remembers....
Cheers, Jerry (N94) 18.8NM W of KMDT on 271.2 radial.
Posted by jonahbird on 03-20-02 at 23:33z
Hi Jerrie
See my reply to Pete. Bob's guidance was given to me in November last year.
Best regards
Frank
Posted by normster on 03-23-02 at 20:02z
Norm at Sunrise, FL
Hi Pete!
Run MSCONFIG and check the STARTUP section. See if there is
any reference to nVidia there. If yes, just delete it.
Cheers!
Posted by PeteDowson on 03-24-02 at 10:51z
Hi Norm,
No, there wasn't anything there. On my flying machine I'm always checking and making sure nothing I don't want is running at start-up. I did get rid of the emblem though, by loading a more recent version of the nVidia drivers, finding and clearing the option, then going back to my older (working) drivers.
Thanks
Posted by RockyJ on 03-26-02 at 01:40z
Didn't read all replies, but if no answer yet, try
win98(other may be similare)
control panel->display->settings->advanced->
GEforce tab or something similar naming your card model->
advanced->3dsettings
should be a 'display logo' option (used by vendors on their sales countertop monitors or somesuch reason)
If this doesn't work, yell and I will try to find the actual reg entry for you.
Posted by PeteDowson on 03-27-02 at 10:55z
Hi Rocky,
That was the first place I went, but there was no such option in the driver version I was using. Someone else mentioned that the option did appear on a specific later version, so I installed that, used it to turn the logo off, then went back to my nice old stable version! <G>
