Thread Number: 389
"FS2K2 Slew Mode."
Posted by andor on 03-07-02 at 03:23z
Am having trouble with the Slew Mode functions in FS2K2, all aircraft, Alt.Increase/Decrease OK-- Left/Right OK, but Ahead speed remains flickering between 2 & 14 knots, Num.Lock off etc. Anyone experience the same and any ideas on cause much appreciated.
TIA,
Regards All,
Andyc
- RE:FS2K2 Slew Mode.,Ben Chiu, 05:42z, 03-07-02
- RE:FS2K2 Slew Mode.,JohnSDavison, 10:16z, 03-07-02
- RE:FS2K2 Slew Mode.,andor, 23:38z, 03-12-02
- RE:FS2K2 Slew Mode.,PaulCroft, 07:43z, 03-14-02
- RE:FS2K2 Slew Mode.,Emile, 07:55z, 03-12-02
- RE:FS2K2 Slew Mode.,Ben Chiu, 18:14z, 03-12-02
- RE:FS2K2 Slew Mode.,Emile, 11:07z, 03-13-02
- RE:FS2K2 Slew Mode.,Ben Chiu, 19:06z, 03-13-02
- RE: FS2K2 Slew Mode.,jimjones, 10:30z, 03-07-02
"RE:FS2K2 Slew Mode."
Posted by Ben Chiu on 03-07-02 at 05:42z
> same and any ideas on cause much appreciated.Greetings Andy:
If you have a joystick or yoke connected to your computer, the FS series has defaulted to using the "elevator" axis for controlling forward/back in slew mode. Try using that or just disable it (Options:Controls:Disable Joystick -- CTRL + k or j if I recall correctly) when you slew.
**** OLR.PL Build 1.68 ****
Posted by JohnSDavison on 03-07-02 at 10:16z
I have a similar problem, except in my case the slew speed is a little faster than the aircraft's normal cruise speed. Using the elevator axis as you suggest makes no difference. I'd be interested in a solution too, if anyone has one.
Regards....John
Posted by andor on 03-12-02 at 23:38z
Thx guys for the suggestions , have tried them out with erratic results, ie hold down Num 8 and suddenly doing 3000+ knots, or 2knots apparently at will.
Ah- Well back to the old "Drag and Drop" in Map view, at least can see where one,s going
Regards Andyc
Posted by PaulCroft on 03-14-02 at 07:43z
Hi Andy> Ah- Well back to the old "Drag and Drop" in Map view, at least can see
> where one,s going
Well I never, that's a new one on me. Must read the instructions more often! I tend to use FSNav for that sort of rapid change of location but map view D&D has its advantages.
**** OLR.PL Build 1.72 ****
Posted by Emile on 03-12-02 at 07:55z
Hi Guys,
What is exactly the "slew mode", I did not find any explanation in the FS2K2 Help.Thanks in advance
Posted by Ben Chiu on 03-12-02 at 18:14z
Greetings Emile:> What is exactly the "slew mode", I did not find any explanation in the
> FS2K2 Help.
Slew mode is a way to move the aircraft to another position and attitude without actually flying there. It works more like a repositioning rather than a teleportation. Try it out. To toggle to slew mode, press the Y key.
**** VPC OffLine Reader Version 3.0.3.1 **** BETA 2 ****
Posted by Emile on 03-13-02 at 11:07z
Greetings Ben,
I use the "Compass-card" icon available in the Pit, this generates a MAP window and I move the aircraft using the mouse (drag)Emile
Posted by Ben Chiu on 03-13-02 at 19:06z
Greetings Emile:> I use the "Compass-card" icon available in the Pit, this generates a MAP
That works too!
"RE: FS2K2 Slew Mode."
Posted by jimjones on 03-07-02 at 10:30z
I have the same problem with a joystick. But I overcome this by using the keypad up and down arrows with the numlock off. Works like a charm. You must hold those arrow keys down for a while b/4 you pick up speed. The joystick can stay attached, but the null may have to be adjusted larger so the joystick does not interfere.
