Thread Number: 384
"ILS w/o DME"
Posted by Guido_Ostkamp on 03-04-02 at 16:54z
Hi all,it seems to me that in FS2000 and now as well in FS2002 there are some
airports with have ILS but no attached DME. I think in FS98 that was not
the case.
So, is this just closer to reality?
Or do I miss some important point?
Guido
**** OLR.PL Build 1.70 ****
- RE:ILS w/o DME,PeteDowson, 17:49z, 03-04-02
- RE:ILS w/o DME,Guido_Ostkamp, 21:07z, 03-09-02
- RE:ILS w/o DME,vgbaron, 22:04z, 03-09-02
- RE:ILS w/o DME,James, 23:54z, 03-09-02
- RE:ILS w/o DME,Guido_Ostkamp, 10:49z, 03-10-02
- RE:ILS w/o DME,James, 13:09z, 03-10-02
- RE:ILS w/o DME,TD, 18:48z, 03-10-02
- RE:ILS w/o DME,PeteDowson, 01:40z, 03-10-02
- RE:ILS w/o DME,PeteDowson, 15:11z, 03-11-02
- RE:ILS w/o DME,PaulCroft, 08:38z, 03-11-02
- RE:ILS w/o DME,Ben Chiu, 04:12z, 03-10-02
- RE:ILS w/o DME,Ben Chiu, 21:23z, 03-10-02
"RE:ILS w/o DME"
Posted by PeteDowson on 03-04-02 at 17:49z
> Hi all,
Hi Guido,> it seems to me that in FS2000 and now as well in FS2002 there are some
> the case.
Yes, very much so. Many ILS's have no co-located DME, especially those at airports which have a VOR/DME on site. The approaches needing DME values are performed using DME measurements from that VOR or another in line with the runway.
If you are doubtful about any specific ones, let me know which and I'll check them on my charts. I don't have very up to date data, but mostly it is okay.
**** OLR.PL Build 1.68 ****
"RE:ILS w/o DME"
Posted by Guido_Ostkamp on 03-09-02 at 21:07z
Hi Pete,> Yes, very much so. Many ILS's have no co-located DME,
> runway.
Thanks, so I will have a problem in aircrafts with a panel
which don't have a display for Nav2.
I have another problem with ILS in FS2002. Maybe you have
some advice for this one as well:
I am in a the default Learjet 45 at N48 14.18', E11 29.83'
at 4000 ft with 130 KIAS approaching runway 22
Oberpfaffenhofen, Germany. Nav1 is set to ILS at 110.50 with
OBS 223. Gear is down, flaps at 8. Autopilot is on with
speed hold to 130, alt hold 4000 ft and approach mode is
activated as well. Localizer already caught, now expecting
to catch glidescope.
After a while, approach mode disables alt hold. Now I expect
to be taken down on the glidescope, but what happens is that
suddenly the glidescope indicator goes up again rapidly, the
plane instead continues to descend. Result is mostly a
crash.
Nearly the same situation in FS98 with Europe 1 Pro scenery
works without problems.
Any ideas?
Guido
"RE:ILS w/o DME"
Posted by vgbaron on 03-09-02 at 22:04z
Guido - From MS -
Intercepting a Glide Slope
Although some real-world autopilots are capable of capturing a glide slope from above, for safety reasons standard operating procedure is to intercept and capture a glide slope from below. Thus, many real-world autopilots can only capture a glide slope from below, and the autopilot system modeled in Flight Simulator 2002 can only capture a glide slope from below. If you want to intercept a glide slope from above, descend through it, level off, and push the APR button twice to disengage and reset approach mode. Then intercept and capture the glide slope from below.
> crash.
**** OLR.PL Build 1.72 ****
"RE:ILS w/o DME"
Posted by James on 03-09-02 at 23:54z
Hi Vic, Guido,Yep, FS2002 is as is
in that the Auto pilot respondes and acts like the real thing
You need to capture the App Loc from below. I've found a lot of problems within Europe
. Not gonna say any thing until others do
"RE:ILS w/o DME"
Posted by Guido_Ostkamp on 03-10-02 at 10:49z
Hi James,> You need to capture the App Loc from below.
I am sure I did. Otherwise I believe, the autopilot would not have
automatically disengaged the ALT HOLD.
Guido
"RE:ILS w/o DME"
Posted by James on 03-10-02 at 13:09z
Hi Guido,>> I am sure I did. Otherwise I believe, the autopilot would not have
> automatically disengaged the ALT HOLD. <<
Hmmm, another clitch in the works
Join the club
I have problems to with all sorts of things and can't pin point them as yet.
James
*** Wishing you all lots of pleasant and enjoyable flights ***
"RE:ILS w/o DME"
Posted by TD on 03-10-02 at 18:48z
so to do this properly, you cannot fly into the path? I am not sure about the use of "above" and "below" and may look like an idiot here (not the first time), but it almost sounds like what you are describing is the same thing, no distinction. Perhaps it is me, but I see the only way to capture a glide slope as starting from a trench or trying to fly into a mesa strip... >Guido -
>From MS -
>from below.
>> crash.
>HTH,
>Vic
> **** VPC OffLine Reader Version 3.0.3.0 **** >red] BETA 2 ****
"RE:ILS w/o DME"
Posted by PeteDowson on 03-10-02 at 01:40z
Hi Guido,> Thanks, so I will have a problem in aircrafts with a panel
For approaches which require you to use DME, yes. but not all or even many ILS approaches do so -- for timing and minimums in poor visibility you use the timer in relation to your altitude, or in very low visibility go to your alternate as your instrument landing will not be valid.
> some advice for this one as well ...
You give all the details, but it would be much easier for me to check if you send the Flight (.FLT) file for that situation for me to try. I don't know how far away you are nor whether you are above or below glideslope. That is the most important thing.
"RE:ILS w/o DME"
Hi Pete,> > I have another problem with ILS in FS2002. Maybe you
> > have some advice for this one as well ...
I think I am below the glidescope. I shall assemble a FLT
file and send it to you - thanks for the offer! Let's
discuss the results here later.
Guido
"RE:ILS w/o DME"
Posted by PeteDowson on 03-11-02 at 15:11z
Hi Guido,
> discuss the results here later.Okay ... I tried your approach.
Several points:
1. You are very heavy (nearly full tanks). I don't know what the maximum landing weight figures are for a LearJet, but I emptied them down to about 20% in each of the three tanks. When the aircraft is too heavy it is not easily controlled, and I think the autopilot won't cope. This is certainly true for the airliners, whether it applies to business jets too I don't know.
2. The speed is therefore rather high too (this follows from the higher weight). I tried it with the approach speed knocked down to 120 and reduced it to 110 on finals. Even that might be a tad too fast.
3. I applied more flaps -- down to 40 at the final stages.
With this, the approach was okay except for the very last 500 feet, when I took over manual control. I don't much like the Learjet modelling (never have <G>), and I really don't think it is good enough for an autoland attempt in any case. If I hadn't taken over the landing would have been a little bit short (by 100 yards or so I think), and heavy as FS doesn't do a flare.
During the approach the Learjet was still slow to manoeuvre and so went through the slope initially, then overcorrected and went beneath it before levelling a bit and getting back onto it. On the final few hundred yards the glideslope isn't any use here anyway. I think the Lear modelling sucks. Maybe there are some better AIR files out there?
I repeated the approach using an aircraft I know better -- the 737-400. With correct flap settings, air speed and weights the approach was much easier, with a perfect landing <G>.
Really I think it is down to getting everything set correctly, early enough, and lowering flaps and airspeed and so on at the right times. I've never been able to do this with the Lear in any case! <G>
"RE:ILS w/o DME"
Posted by PaulCroft on 03-11-02 at 08:38z
HI Guido> I have another problem with ILS in FS2002. Maybe you have
I've noticed this problem too, not in the Learjet because I don't fly that much, but in the 747. What appears to happen, at least for me, is that the sim adjusts the trim too slowly so that, by the time the plane's trimmed for a downward 3 degree glide, the glideslope is now too far below the plane and the glideslope capture is lost. Result: the plane is now descending down and through the glideslope from above and fails to re-capture it.
The only solution I've so far found is to approach from below as before but, when the glideslope indicator starts to move, disconnect the alt hold, adjust for, say, an alt of 1500 ft less, select a v. speed of about 200 fpm then re-connect the alt hold. As the plane now descends adjust the v. speed such that, when the plane meets the glideslope capture, it is already descending at about 500 fpm.
With a less radical difference in current descent rate and glideslope descent rate I have a much better success rate at glideslope capture.
Maybe not very real worldish but it keeps me on my toes.
Before I figured this out I'd crash the 747 every time on approach - usually with a descent rate of at least 3000 fpm
"RE:ILS w/o DME"
Posted by Ben Chiu on 03-10-02 at 04:12z
> airports with have ILS but no attached DME.Greetings Guido:
DME is not a required component of an ILS system. ILS include the localizer (horizontal guidance), glideslope (vertical guidance), and marker beacons (distance distance). If you have an approach plate (which legally you need to have onboard to attempt an approach), you don't need DME.
"RE:ILS w/o DME"
> distance). Thanks, Ben. I just feel better when I know, how far out I
am. I sometimes used the DME readout to decide when to lower
the gears, flaps schedule etc. On the approach charts one
almost always find hints which altitude one should have at a
certain distance. Guess, this stuff is then impossible to
check if not related to the markers.
Guido
"RE:ILS w/o DME"
Posted by Ben Chiu on 03-10-02 at 21:23z
Greetings Guido:> Thanks, Ben. I just feel better when I know, how far out I
The procedure I teach is to stabilize the airplane in approach configuration (gear down, approach flaps setting) before intercepting the LOC. It works pretty well.
