Thread Number: 361
"joystick"
Posted by countryhull on 02-19-02 at 06:35z
Why doesnt my throttle completely kill power - flt sim 2002 and force feed back pro- I have rebooted and calibrated. Is there a key I can push to calibrate while flying?
"RE: joystick"
Posted by Ben Chiu on 02-19-02 at 20:51z
Greetings countryhull:
>calibrated.
Are you're talking about the engine stall when idling after a few minutes with the throttle left all the way back, or an instantly killing the engine?
>flying?
Not that I know of.
"RE: joystick"
Posted by countryhull on 02-19-02 at 21:02z
>>calibrated.
>>flying?
>Not that I know of.
>Ben
When game starts, if I turn throttle all the way off on my joystick (force feedback pro, first one) the engine will not go down to an idle. I have to hit f1. Also, if I give it full throttle on my joystick, the engine will not go to full power. I have to hit f4. I have calibrated. Thanks for the info
"RE: joystick"
Posted by Ben Chiu on 02-19-02 at 21:05z
>for the info
If the throttle does move in the sim (at least a little), then it sounds like your sensitivity setting on the throttle is too low. Try moving it all the way to the right.
"RE: joystick"
Posted by countryhull on 02-19-02 at 21:46z
>>for the info
>right.
>Hope this helps!
>Ben
Thanks, That did the trick
