Thread Number: 336
"Cessna Citation CJ1"
Posted by andor on 02-04-02 at 23:59z
Have just installed the CJ1 onto FS2K2, the panel is similar to the Lear but lacking in Avionics having only Nav.1 functional.
Is it possible to download a GPS into the CJ1 folder and if so where could I find one.
Also is it possible to activate the Nav.2 and DF systems shown on the radio stack.
It also will not accept the use_no_default_ bank=1 etc.
in the Auto Pilot section , isolating the Alt. Hold. from the Hdg.Hold
Any info. and help will be greatly appreciated.
Regards @ TIA
Andyc
"RE: Cessna Citation CJ1"
Posted by Ben Chiu on 02-05-02 at 08:41z
Greetings Andy:
If your CJ ("near-jet" as Gunner calls them :) ) panel is an actual panel rather than an alias to the Learjets, you should be able to edit panel.cfg to add a GPS window.
Search our messages here for the thread where Mel wanted to add a marker beacon to his DC3. The procedure is the same, but the code you'd add would be:
size_mm=150,250
position=8
BACKGROUND_COLOR=16,16,16
VISIBLE=0
ident=GPS_PANEL
gauge00=gps!gps,0,0,150,250
>the Hdg.Hold
You might ping the aircraft author/designer on these issues.
Hope this helps.
Posted by vgbaron on 02-05-02 at 17:39z
Andy -
Found this at Flightsim in the FSTips area. Can't hurt to try -
Add this code to your aircraft.cfg to all of your aircraft in order to have your NAV2 unit operational in FS2002 on imported aircraft. Copy and paste.
// Radio Type=availiable, standby frequency, has glide slope
Audio.1=1
Com.1=1, 1
Com.2=1, 1
Nav.1=1, 1, 1
Nav.2=1, 1, 0
Adf.1=1
Transponder.1=1
Marker.1=1
