Thread Number: 290
"Sancho Memorial Flight IP Update"
Posted by James on 01-17-02 at 23:16z
Hi Guy's,
Just thought I'd inform you that if any one wish's to join me on a Multi Player Session for this flight can do so as I will be posting an IP Address around lunch time Sunday. Take Off time is 15:30 so the MP Session will be up and running at 15:00.
I'm flying the R4D-6 DC-3 with FS2002.
Regards and have a safe flight.
"RE: Sancho Memorial Flight IP Update"
Posted by RandyHaskins on 01-18-02 at 02:00z
Hello James,
Are those times Zulu time?
Randy
Posted by James on 01-18-02 at 17:47z
Hi Randy,
Nope, GMT :-)
Posted by Vulcan on 01-18-02 at 17:03z
Are we running through a VPC flight room or just a straight connection through FS to you James?
'Vulcan'
8nm NE of EGCC
Posted by James on 01-18-02 at 17:48z
Hi Vulcan,
Direct through me. The IP for Roger Wilco will be the same one used for the VCP Pilots Lounge.
Posted by KaptainKit on 01-19-02 at 10:18z
Hi James,
>same one used for the VCP Pilots Lounge.<
Run that past me again please? Is there a permanent IP for the Pilots Lounge? If so I haven't found my way to that bit of the IPC yet.
Melo and I are planning a joint flypast over Berne in Sancho's honour, Melo in a TWA Super Connie and me in a TWA Starliner. We were planning to run our own MP session for it, but it might be better to join yours.
I have RW but I'm not 100% sure that it works, so can we still fly in your session without it?
Kit
Posted by James on 01-19-02 at 11:16z
Hi Kit,
>> Run that past me again please? <<
A quick way to do this :-) is start RW and click on Join. In the top IP Address line place the following :-
64.163.145.151/122.95 then click on Join. Hope this works for you.
You are all more than welcome to join me :-)
Regards and Happy Flying,
Posted by Ben Chiu on 01-19-02 at 18:47z
>for you.
Of course you can just go to VoiceCOM and click UNICOM 122.95 and it'll launch RW and tune in the right channel for you automatically too. :)
Posted by James on 01-20-02 at 00:12z
He he, was looking at that but couldn't see it :-) if you know what I mean :-)
