Thread Number: 243
"Nav Sounds in FS2002?"
Posted by Tarmack on 12-26-01 at 13:11z
Could anyone tell me where I ENABLE the Nav sounds of the Outer, Middle, and Inner markers for 2002?I have searched all the .cfg files....and I am stumped.
Not hard to stump me of course....but this one must be easy to overlook?
- RE: Nav Sounds in FS2002?,RandyHaskins, 13:20z, 12-26-01
- RE: Nav Sounds in FS2002?,vgbaron, 16:55z, 12-26-01
- RE: Nav Sounds in FS2002?,Tarmack, 22:12z, 12-26-01
- RE: Nav Sounds in FS2002?,Ben Chiu, 00:57z, 12-27-01
- RE: Nav Sounds in FS2002?,Tarmack, 11:20z, 12-27-01
- RE: Nav Sounds in FS2002?,Ben Chiu, 18:24z, 12-27-01
- RE: Nav Sounds in FS2002?,Tarmack, 21:44z, 12-27-01
- RE: Nav Sounds in FS2002?,James, 00:13z, 12-28-01
- RE: Nav Sounds in FS2002?,Tarmack, 11:10z, 12-28-01
- RE: Nav Sounds in FS2002?,James, 17:50z, 12-28-01
- RE: Nav Sounds in FS2002?,Tarmack, 23:09z, 12-27-01
- RE: Nav Sounds in FS2002?,James, 00:15z, 12-28-01
- RE: Nav Sounds in FS2002?,Ben Chiu, 02:59z, 12-28-01
"RE: Nav Sounds in FS2002?"
Posted by RandyHaskins on 12-26-01 at 13:20z
Hi Mel,>Could anyone tell me where I ENABLE the Nav sounds of the
>easy to overlook?
>Regards,
>Cap'n Tarmack
I can't remember where to find it on the larger planes. But on the 172 there's a button on the upper row of the radio stack for the beacon sounds. I assume it on the radio for other planes as well.
Randy
Posted by vgbaron on 12-26-01 at 16:55z
Mel - There's a row of switches on the radio stack that controls the markers, dme, etc.
Posted by Tarmack on 12-26-01 at 22:12z
Vic...and Randy,Thanks for the replies.....guess the radio rack is the only area for the enabling of the Marker sounds.
Trouble is....there is no radio rack available in the R4D DC-3.....so I guess I will just have to play REAL old pilot and not be able to hear the Outer Marker when I go by it....I can still see it. Grin.
Posted by Ben Chiu on 12-27-01 at 00:57z
>by it....I can still see it. Grin. Greetings Mel:
This is the only thing I can suggest:
Save a flight and edit the corresponding *.flt file.
Look for the section
(square bracket)Avionics(square bracket)
and change
AudioMarkerListen=0
to
AudioMarkerListen=1
Save the file and load it when you want to have the marker beacons audible. I haven't tried it with the DC-3 you're referring to, but it should work.
Posted by Tarmack on 12-27-01 at 11:20z
Thanks very much......this looks VERY promising.....I will report back later today and the success of.....or lack therein....but I think you win the prize!
Mel
Posted by Ben Chiu on 12-27-01 at 18:24z
Greetings Mel:You know, after replying to another message about the AP panel, you could probably do the same for the COM panel.
You could try modifying panel.cfg:
Under (square bracket)Window Titles(square bracket)
add:
window05=COMPanel
Under (square bracket)Window05(square bracket)
add:
BACKGROUND_COLOR=2,2,2
size_mm=156,45
position=8
visible=0
ident=RADIO_STACK_PANEL
gauge00=Bendix_King_Radio!Bendix-King Radio Audio, 0, 0
This would make the COM panel accessable by key command shift + 6
Best!
Posted by Tarmack on 12-27-01 at 21:44z
Boy am I glad that you are full of ideas....cuz I was running out of them!
I can get the Marker sounds with the default Cessna's....and I modified the aircraft file for the DC3 as you recommended.....but to no avail.....no sound when over the Outer, Middle or Inners.
Now...with this new idea I have plans for tomorrow. Grin.
Must tell you ALL....if you can download almost a HALF GIG of terrain mesh by Eddie Denney.......DO IT!
It is for Alaska and it is amazing.
Today I flew the entire length of the Yukon river...and I am still amazed.
Mel
Posted by James on 12-28-01 at 00:13z
Hi Mel, >>I can get the Marker sounds with the default
over the Outer, Middle or Inners. <<
This you may find is due to it not being a fully pledged FS2000/2002 air file aircraft mate
>>Must tell you ALL....if you can download almost a HALF GIG of terrain mesh by Eddie Denney.......DO IT! It is for Alaska and it is amazing. <<
Try Justin's (www.fsgenesis.com) Mesh Terrain also, amazing
Posted by Tarmack on 12-28-01 at 11:10z
James,I ordered Justin's Mesh on Wednesday.....awaiting the shipment!
Mel
Posted by James on 12-28-01 at 17:50z
Mel,Enjoy it when you get it
Regards and A Happy New Year to you my friend,
Posted by Tarmack on 12-27-01 at 23:09z
Well, I could NOT wait until tomorrow....as there was still light of this day. Grin.
Yup....you fixed me up.....AGAIN!
Sounds of the OM, MM, and IM are IN the DC-3!
Thanks VERY much!
Mel
Posted by James on 12-28-01 at 00:15z
Hi Mel,Never read this prior to the last reply but, will have to try this myself
as I didn't think it would work
Posted by Ben Chiu on 12-28-01 at 02:59z
>Thanks VERY much! My pleasure, Mel. Glad I could help.
Happy New Year!
