Thread Number: 233
"FS2002 B777"
Posted by maurice on 12-20-01 at 22:10z
The B777 flies nicely on my set-up now that I've calmed down its excessive default max thrust using FS2002 Edit.However, I find taxying the 777 less than satisfactory because when trying to carry out a tight turn the nosewheel will turn to 90deg somewhere about half travel of the CH Pro pedals which then stops the aircraft. It's very tricky to avoid the point at which this occurs.
I don't want to change the pedals sensitivity because all the other aircraft steer well with pedal movement up to max travel.
Is it possible to change a parameter or two in the B777's files to correct this effect?
Maurice (UK)
- RE: FS2002 B777,maurice, 18:33z, 12-24-01
- RE: FS2002 B777,PaulCroft, 01:45z, 12-29-01
- RE: FS2002 B777,maurice, 07:44z, 01-10-02
- RE: FS2002 B777,PaulCroft, 09:53z, 01-10-02
- RE: FS2002 B777,James, 16:58z, 01-10-02
- RE: FS2002 B777,PaulCroft, 22:52z, 01-10-02
"RE: FS2002 B777"
Posted by maurice on 12-24-01 at 18:33z
No reply needed fellahs. Found out how to do it.M.
"RE: FS2002 B777"
Posted by PaulCroft on 12-29-01 at 01:45z
Hi MauriceDo you want to let others (like me) in on the secret? I, too, find it a pain in the butt.
10 miles south east of LHR
"RE: FS2002 B777"
Posted by maurice on 01-10-02 at 07:44z
Hello Paul,Sorry about the delay in replying to you post. I'm not completely used to this forum yet. It would help if the e-mail notification of a message was checked by default. (But I always liked to be spoonfed<g>).
Adjust the max gear steering angle in FSEDIT. I find that a setting of 55deg much better. If you can't find that setting in FSEDIT post back.
M. (1DME N Gatwick)
"RE: FS2002 B777"
Posted by PaulCroft on 01-10-02 at 09:53z
Hi Maurice>Adjust the max gear steering angle in FSEDIT. I find that
Is FSEDIT a commercial app or is it somewhere on the FS2k2 CDs?
"RE: FS2002 B777"
Posted by James on 01-10-02 at 16:58z
Hi Paul,>> Is FSEDIT a commercial app or is it somewhere on the FS2k2 CDs? <<
You'll find it in the same place as it was in FS2000 mate. In the FS root Directory.
Have fun and Happy Flying
"RE: FS2002 B777"
Posted by PaulCroft on 01-10-02 at 22:52z
>Hi Paul, >You'll find it in the same place as it was in FS2000 mate.
Ah, best I go and have a look then. Time for some more tinkering. Thanks for the heads up.
