Thread Number: 213
"Very Impressed with FS2K2!"
Posted by Madape on 12-12-01 at 12:12z
Hi AllI finally managed to spend 60 of my student pounds on this great sim, and its definitely worth it, I am extremely impressed with the new graphics, ATC etc.
I am a bit dissapointed with my frame rate of 25 - 30 FPS although I am running an 800Mhz, 320 RAM, gonna have to test it out on one of my neighbours faster machines!
I used to be an avid X-Plane fan, although that seems to have changed!
Sam
- RE: Very Impressed with FS2K2!,vgbaron, 16:54z, 12-12-01
- RE: Very Impressed with FS2K2!,Madape, 18:28z, 12-12-01
- RE: Very Impressed with FS2K2!,vgbaron, 21:43z, 12-12-01
- RE: Very Impressed with FS2K2!,RandyHaskins, 03:17z, 12-13-01
- RE: Very Impressed with FS2K2!,Madape, 14:51z, 12-13-01
- RE: Very Impressed with FS2K2!,RandyHaskins, 02:27z, 12-14-01
- RE: Very Impressed with FS2K2!,Madape, 09:32z, 12-14-01
- RE: Very Impressed with FS2K2!,RickLee, 21:21z, 12-13-01
"RE: Very Impressed with FS2K2!"
Posted by vgbaron on 12-12-01 at 16:54z
>test it out on one of my neighbours faster machines! Sam -
I run an Athlon 1.4 and I have it locked at 20fps. No stutters and smooth flights. I ran it at 50+ and saw no real change in flight mode but the scenery suffers as FS2K2 tries to maintain the frame rate. 18-20 is very realistic and you should see no flickers, If you try to push the fps to max, you get a big hit in the scenery with no apparent gain in flight.
There are several discussions re the locked frame rate on the other flightsim forums.
Posted by Madape on 12-12-01 at 18:28z
Hi Vic,Thanks for your suggestions, I've found Frame Rate to be a very personal opinion, as I play alot of 3d Shoot ups such as Unreal Tournament, Return to Castle Wolfenstein, I am used to quite high frame rates 40FPS +.
The thing that bugs me off is that the flight is lovely smooth, but the instruments stutter like crazy! I have to admit I like the graphics on high
, its no real problem as I fly VFR mainly.
Thanks again
Sam
Posted by vgbaron on 12-12-01 at 21:43z
Hi Sam,>The thing that bugs me off is that the flight is lovely
The 747 panel stutters badly but there is a fix out there. The others I've tried seem to work fine. But, as you said, framerates are a purely subjective matter.
TTYL,
Posted by RandyHaskins on 12-13-01 at 03:17z
Hi Sam,I agree about the instruments stuttering now. It's almost like MS switched things around this time. Priority on flight and external graphics. With the gauges taking the hit.
-Randy
Posted by Madape on 12-13-01 at 14:51z
Hi RandyWonder if you could tell me what kind of spec machine you are running?
Cheers
Sam
Posted by RandyHaskins on 12-14-01 at 02:27z
Hi Sam,>Hi Randy
>are running?
>Cheers
>Sam
I've got a 1 gig Athlon, 256 meg of memory and a GeForce2MX400.
I don't have a complaint about the gauges. They just don't seem quite as smooth previous versions.
Randy
Posted by Madape on 12-14-01 at 09:32z
Hi Randy,I just wanted to compare them to my system, it seems we have a very simialr system, exact same graphics card.
Cheers
Sam
Posted by RickLee on 12-13-01 at 21:21z
I don't have any problem with instruments... but so far I'm only flying props.Rick Lee www.rickleephoto.com
