Hi Vic,>>I just got a dsl line, hooked to a router, and all of a sudden when I try to d/l real weather I get an error re "server name could not be resolved".
Are hey having trouble or is my router causing a problem?<<
Yup, the server is acting as a firewall. You need to open the port that FS is using to get the weather. Which port that is, I don't know. Why are you using a router anyway? If you're sharing the connection in a lan, wouldn't ICS be a cheaper solution? I use it at my home and office, and it works great. The only downside I can see is that the "server" computer needs to be on all of the time for others to access the internet.
Tom is our network guru around here, so hopefully he'll jump in with which port FS uses to dl the wx.
>Hi Vic,
>problem?<<
Hi Greenie - Tracked it down. In addition to the router I use zoneAlarm pro on each system. With all the tweaking, connecting, upgrading, etc. I forgot to tell ZA to allow FS to connect to the inet. All is well now.
Thanx,
