Thread Number: 170
"FS2002: Blurry Textures w/ G2 64 Ultra"
Posted by TJPIETRO on 11-17-01 at 00:24z
Any clue how to fix this things and problem? I've see a lot of guesses (fps, change terrain file, drivers, etc...).
Tim
"RE: FS2002: Blurry Textures w/ G2 64 Ultra"
Posted by Ben Chiu on 11-17-01 at 04:26z
Greetings Tim:
I don't have FS2K2 or a G2 64 Ultra, but my *guess* would be (provided that you've seen FS2K2 on another systems and have confirmed that what you're seeing is just the way the program is) that you may have forced antialiasing enabled.
If the G2 64 Ultra should have it's antialiasing setting in the 3D Antialiasing tab. If you don't know where that is, let me know.
Hope this helps.
Posted by TJPIETRO on 11-17-01 at 05:03z
So, I should turn this off both on the card (options are 2x, 4x, or off) and in Fs2002. Is this what they mean by FSAA?
Tim
Posted by Ben Chiu on 11-17-01 at 06:19z
Greetings Tim:
>FSAA?
You'll have to play with it and see what you like. As they say, "blurry is in the eye of the beholder." Well, something like that. ;)
Posted by TJPIETRO on 11-27-01 at 23:01z
Does anyone have a sure fix for this yet?
I have a pentium 850, G2 Ultra 64 with 380 RAM.
Tim
Posted by Ben Chiu on 11-28-01 at 08:24z
Hi Tim:
Did turning antialiasing off do anything for you blurry textures? Have you tried running FS at a different resolution (higher or lower)?
Posted by RickLee on 11-28-01 at 16:13z
I would also experiment with the different filtering settings (off, bi, tri). I believe that that is the setting that blurs the textures. This is designed to get rid of the "sparkling" texture effect isn't it?
Rick Lee
www.rickleephoto.com
AIM: RickLeeFS
Posted by Grunt on 12-03-01 at 03:17z
What do you have the Aircracft texture size slider set to? Try putting it on Massive.
>Greetings Tim:
>is, let me know.
>Hope this helps.
>Ben
Posted by DeeWaldron on 12-03-01 at 03:40z
If you have MIP Mapping turned on, try turning it off. Thats in the FS2002 Options/Display/Hardware...
Cheers,
Dee
