"IMPORTANT VPC UPDATE: Please Read!"
08-26-02, 02:51z
Greetings:
The VPC has been making a technological move to more efficient and robust ActiveX components over the last couple of months, and the time has come for us to make the change over. In a few days, we'll be shifting core areas to these new components. Once we make the move, all of the VPC's feature areas will require that you have ActiveX enabled in your browser to function correctly. The most efficient way to enable ActiveX without changing your security settings for all other web sites is to add *.flightadventures.com to your Trusted Sites list in your browser with the Trusted Site zone set to the Low level with ActiveX enabled for all ActiveX settings.
  • If you are running Internet Explorer you can automatically configure your browser for VPC operation by using the following utility. Click http://www.flightadventures.com/misc/VPC_cfg.exe and select Run this program from its current location, and select "Yes" when the warning box appears.
    OR
  • If you are running some other browser or wish to manually make these configuration changes yourself, we have step-by-step instructions on how to add *.flightadventures.com to your trusted sites list at the following link http://www.flightadventures.com/faq/faq_vpc.htm#4h or visit the VPC FAQ's at any time.
From this day onward, all new registered members will be notified of the ActiveX requirements when they register. However, if you've been visiting the VPC prior to 8/25/02 you will need to make this one-time change ASAP.
This latest update is the result of the VPC Staff's continuing mission to make your online experience as pleasurable and trouble-free as possible. We know you'll enjoy the upcoming improvements.
Thank you!
