RobertVA
"Nov 20 0300 Multiplayer Plan"
11-20-05, 00:51z
LAST EDITED ON 11-20-05 AT 00:54z ()Pocatello Rgnl. to Boise Air Terminal/Gowen | Beechcraft Kingair 350 | Waypt. Code | Waypt. Name | Navaid Code | Navaid Name | Navaid Radial | Navaid To / From | Navaid Type | Navaid Freq. | Alt. | Hdg. | Dist. | Est. Gnd. Speed | ETE (hh:mm) | | KPIH | Pocatello | | | | | | | 4,452 | | | | | | PIH | | | | | | | | 6,500 | 216 | 4 | 160 | 00:02 | | DERSO | | PIH | Pocatello | 270 | From | VOR/ DME | 112.60 | 18,500 | 270 | 113 | 240 | 00:29 | | | | BOI | | BOI | Boise | 267 | To | VOR/ DME | 113.30 | 3,000 | 267 | 48 | 235 | 00:12 | | KBOI | Boise Air Terminal | BOI | Boise | 279 | From | VOR/ DME | 113.30 | 2,868 | 279 | 1 | 100 | 00:01 | | | | Totals: | 165 | | 00:44 | | Departure Airport: | Pocatello Rgnl. | Code: | KPIH | Altitude: | 4,452 ft. | | Latitude | Longitude | ATIS | UNICOMM | MULTICOMM | Tower | CTAF | | 42°54.59N | 112° 35.75 W | | 122.950 | | 119.100 | 119.100 | | | Rwy. | Length | Navaid Hdg. / ID | Navaids | Frequency | Navaid Hdg. / ID | Navaids | Frequency | | 3/21 | 9,051 ft. | | | | 210(IPIH) | ILS/DME | 110.30 | | 16/34 | 7,147 ft. | | | | | | | | | | Destination Airport: | Boise Air Terminal/Gowen | Code: | KBOI | Altitude: | 2,868 ft. | | Latitude | Longitude | ATIS | UNICOMM | MULTICOMM | Tower | CTAF | | 43°33.87N | 116° 13.37 W | 123.900 | 122.950 | | 118.100 119.000 | | | | Rwy. | Length | Navaid Hdg. / ID | Navaids | Frequency | Navaid Hdg. / ID | Navaids | Frequency | | 10L/28R | 9,986 ft. | | | | | | | | 10R/28L | 9,749 ft. | 99(IBOI) | ILS/DME | 111.10 | | | | | | - Due to proximity of Pocatello VOR (PIH) to Pocatello Rgnl (KPIH) set HSI for PIH-DERSO leg and aquire outbound radial without using VOR for KPIH-PIH leg.
- Safe to reduce altitude to 10,500 until 65nm from PIH and to 12,500 until 87 nm from PIH on PIH-BOI leg
- Tune second NAV radio to BOI in case signal from PIH not available all the way to DERSO.
- Boise VOR (BOI) appears to be positioned for VOR approach to KBOI runway 28L. Distance from VOR to runway threshold MAY be less than shown on plan.
- FS 2004 GPS lists jet fuel available at both airports.
Robert Near KORF
