"June 5 0200z Multiplayer Plan"
RobertVA[Lead]
06-04-05, 17:56z
Le Raizet to Princess Juliana Intl.
Beechcraft Kingair 350
Waypt.
Code
Waypt.
Name
Navaid
Code
Navaid
Name
Navaid
Radial
Navaid
To / From
Navaid
Type
Navaid
Freq.
Alt. Hdg. Dist. Est. Gnd.
Speed
ETE
(hh:mm)
TFFR Le Raizet             36
BIMBO   PPR Pointe
A Pitre
325 From VOR/
DME
112.90 8,500 325 33 210 00:09
SKB   SKB Golden
Rock
  To NDB 325.00 8,500 324 60 240 00:15
OTMUT   PJM Saint
Maartin
347 To VOR/
DME
113.00 8,500 347 35 240 00:09
UMANA               4,000 305 17 240 00:04
BOPER               3,000 004 5 120 00:03
TNCM Princess
Juliana
Intl.
PJM Saint
Maarten
94 To VOR/
DME
113.00 13 094 10 110 00:05
Totals: 161   00:45
Departure Airport: Le Raizet Code: TFFR Altitude: 36 ft.
Latitude Longitude ATIS UNICOMM MULTICOMM Tower CTAF
16°15.85N 61°31.55W
    118.400
Rwy. Length   Navaid
Hdg. / ID
Navaids Frequency Navaid
Hdg. / ID
Navaids Frequency
11/29 11,515 ft. 115(PP) ILS 110.30
Destination Airport: Princess Juliana Intl. Code: TNCM Altitude: 13 ft.
18°2.40N 63°06.70W       118.700
Rwy. Length   Navaid
Hdg. / ID
Hdg. / ID
Navaids Frequency
9/27 7,550 ft. 94/(PJM)  VOR/DME* 110.30
* Saint Maarten NDB (PJD 118.70) AND VOR/DME (PJM 113.00) located to south of runway near west end.
  • Intersection OTMUT is 14.2 DME from VOR/DME PJM
  • Intersection UMANA is 16.6 DME from VOR/DME PJM on radial 067/247.
  • Watch for terrain if go around required at  Princess Juliana (TNCM)
Check out the fenced enclosure to the right of the runway! Also if you want to switch to a helicopter or other low speed plane (or even taxi across the grass) check out the jet blast warning sign opposite the fort.
  RE: June 5 0200z Multiplayer Plan RobertVA[Lead] 06-05-05 1
RobertVA[Lead]
1. "RE: June 5 0200z Multiplayer Plan"
06-05-05, 07:50z
I seem to have resolved the problems I was experiencing during the multiplayer session. Reversing the airflow direction of my add in case fan lengthened the time between spontaneous reboots. Leaving the main access panel off the side of the computer seems to have stopped the spontaneous reboots entirely. All the fans; power supply, case (now exhausting air), CPU and video accelerator; are working. There doesn’t seem to be any dust remaining on the vents or heat sink fins. A popular utility reports lower motherboard, CPU and hard drive temperatures with the case fan installed to exhaust air. The temperatures are even lower with the left panel off.
Now experiencing 43°C on motherboard, 36°C on CPU and 35°C on hard drive after running FS connected to persistent world server for two hours (access panel off). I had RW connected the whole time.
I will probably look into acquiring at least one more fan in the hopes I will be able to reinstall the side panel. I got along without the case fan last year, but I suspect the larger hard drive generates more heat than the old one.
