"Cold Engine Startup"
nords[Guest]
Click to EMail nords Click to send private message to nords Click to view user profile
03-05-05, 00:15z
Hello
How can I create a flight in FS2004 that I will be able to start myself the engine. Because the engine are always running when I create a flight.
Thanks you
  RE: Cold Engine Startup RobertVA[Lead] 03-05-05 1
   RE: Cold Engine Startup nords[Guest] 03-07-05 2
RobertVA[Lead]
1. "RE: Cold Engine Startup"
03-05-05, 20:38z
Try this:
Set the default aircraft and airport you want and click the "Fly Now" button.
Shut the engine(s) down.
Save the flight. For this you can use the menus or the ";" key. When saving, select the "Make this the default flight" box.
nords[Guest]
2. "RE: Cold Engine Startup"
03-07-05, 00:57z
Thank you
But I have a found a little file that made all my plane dark at start-up
:D
