"Acronyms"
jonahbird[Crew]
Click to send private message to jonahbird Click to view user profile
"Acronyms"
03-05-03, 07:11z
Does anyone know of a comprehensive glossary of flying acronyms. In particular I have recently been racking my poor old grey cells for 'AFCAD'.
We're all familiar with RTFM :-) but where's the manual for these blasted initials?
Regards to all
Frank
  RE: Acronyms andrewluck[Crew] 03-05-03 1
   RE: Acronyms jonahbird[Crew] 03-05-03 2
   RE: Acronyms vgbaron[Sysop] 03-06-03 4
  RE: Acronyms Ben_Chiu[Admin] 03-05-03 3
   RE: Acronyms jonahbird[Crew] 03-06-03 5
andrewluck[Crew]
Click to EMail andrewluck Click to send private message to andrewluck Click to view user profile
1. "RE: Acronyms"
03-05-03, 07:29z
Frank
A Google search on 'aviation acronyms' turns up pages of them. Didn't see AFCAD though.
Andrew Luck
18 SW EGSH
jonahbird[Crew]
2. "RE: Acronyms"
03-05-03, 10:01z
Hi Andrew
Thanks for that heads up
Frank
4. "RE: Acronyms"
03-06-03, 01:40z
Hi Andrew -
From the readme -
3. What is AFCAD?
It is a freeware CAD-style program that allows you to modify the Airport and Facilities Data (AFD) used in Microsoft Flight Simulator (FS2002). Facility data is part of the scenery database for Flight Simulator but facility data does not control any of the visual elements of scenery, like airport buildings or ground textures. Instead facility data controls the invisible maps of airports and other data that ATC uses to give directions and AI uses to move around and park at airports. It also controls the information that you see on the ?map view?, GPS screen, flight planner, and start position set-up window in Flight Simulator. You can modify any of that with AFCAD.
AFCAD is a third party program for modifying the Airport files. It allows you to add gates, etc and much more. Not sure exactly what AFCAD stands for but the CAD part is probably Computer Aid
3. "RE: Acronyms"
03-05-03, 23:41z
Greetings Frank:
> 'AFCAD'.
In what context was AFCAD used e.g. where did you see it?
jonahbird[Crew]
5. "RE: Acronyms"
03-06-03, 18:25z
Hi Ben
I think Vic has solved it. I would think it means 'Airport Facilities Computer Assisted Drawing'. He certainly describes what it does.
AFCAD airport facility files are installed using software developed by Lee Swordy. It is simple to use. These text files are dragged and dropped into the program window, and they are installed instantly.
BTW using google led me to discover a super sounding manual by Bill Stack. Does anyone know this product?
Frank
