Hi Emile,> Is it possible for me to install on my HD a 2nd FS2002 PRO in an
> other folder than the standard one? Without any risks on the one already
> installed!!!!!
I've always done this. Because I do a lot of development and testing, I need a base "virgin" installation in order to compare results. So what I do is install FS to where I want it (*never* the default location where is would like to go -- I always install it on a second hard disk or partition, away from Windows, and with a nice short folder name, like D:\FS2002).
Then I either make a copy of it (the whole folder, getting "Copy of FS2002") to keep as my "virgin installation", or , more usually, rename that folder (e.g. to "FS2002 Original") and install it again to D:\FS2002.
I would suggest you do the same. Simply rename your current FS folder, the install a fresh complete copy to the same original folder name. This is assuming you have the space, of course.
Then you can do one of two things:
EITHER copy bits from the new installation to the old one, to make up for the bits you are missing. Then rename the folders again so that your now complete old installation is the one registered in the Registry,
OR build up your new installation with the add-ons from your old one. To start with simply copying across your FS2002.CFG file will get your base options set. You can even copy across add-on programs, aircraft, scenery (don't forget the SCENERY.CFG file in this case) which registered themselves in your registry, since they will have been registered with that original folder name in any case, so they still stay properly installed.
I tend to favour the first method, as that at least always gives you a place to get original parts from, or to run as a test should you try an add-on which seems to muck things up. Of course, it will be taking up 2Gb of disk space, so you might want to get rid of it quite soon, instead. <G>
