"is there a fix for sensitive rudder using linear control utility in fsx"
Kramsman
Click to EMail Kramsman Click to send private message to Kramsman Click to view user profile
01-29-08, 01:36z
I have just begun using FSX and am having the same problem I had in FS2004, namely over sensitive controls, especially rudders. I use a CH yoke and rudder, and nothing helped until I installed the "linear control utility" posted on this site (see the prior post I have copied below). It was like magic (thank you very much)!
Is there a way to use the utility with FSX? The posting states it is for use only with Windows XP (which I am using for FSX), but makes no mention of FSX.
Thanks
This FlightAdventures install will configure your installation of
Microsoft Flight Simulator 2004's controller operation to behave in a
linear fashion as opposed to the default time-delay operation. In our
experience, linear controller operation is more realistic.
http://files.flightadventures.com/dl.pl?FS2004XPlinearcontrollersetup.exe
  RE: is there a fix for sensitive ru... Ben_Chiu[Admin] 02-03-08 1
1. "RE: is there a fix for sensitive rudder..."
02-03-08, 22:08z
> mention of FSX.
That's a good question. I don't have FSX installed, so I never tried it.
